Good amp???
the IA 20.1 is easily the best amp in this debate. Lanzar Opti is pretty good stuff actually. I still wouldnt run it over the AQ, IA or Cresendo, but the people that think Opti is on par with the Vibe or Vector lines are greatly mistaken
actually its the 3d best. the db drive and bc2000 clamp alot better
idk what clamp tests you have seen then....and even if the IA clamped the least, which it doesnt, that would not solve the debate. Those IAs are ran down at .25 loads by alot of their users. People have pushed those things down to the 10v range and they are still basically bullet proof. **** near dead short those things
lets settle it. ill clamp mine tomorrow. it was set via dd-1
you are blind
i seen what the guy clamed it did, probably clipped to ****. and if you set ur amp with the dd1 any voltage drop is gonna induce major clipping.
also i set my amp with track 3 and i still have clipping going on, so if u did ur with 5 or 7 then ur majorly clipping ur ****.
RoYALbLUE08
RoYALbLUE08
NYC
RoYALbLUE08
