Good amp???
RoYALbLUE08
is this lanzar a good amp???
is this better than hifonics? should i spend the extra 100 bucks on this one instead of hifonics brutus 2100?
i dont like buying used things i only buy new so whats my best bet for 2000 watts rms?
Lanzar OPTI3201D 3200W RMS Monoblock Class D OptiDrive Car Amp
OptiDrive Series Monoblock Class D Car Amplifier
RMS Power Rating:
4 ohms: 820 watts x 1 chan.
2 ohms: 1500 watts x 1 chan.
1 ohm: 2100 watts x 1 chan.
0.5 ohm: 3200 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +18 dB)
Soft Start Turn-on
Double sided Epoxy PCB circuit board
Mono channel operation
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Gold-plated RCA level inputs
Custom Terminal Block for speaker connections
Input sensitivity:
Low level: 200V-8V
Variable low-pass filter (50-250 Hz, 24 dB/octave)
Subsonic filter (15-40 Hz, 24 dB/octave)
Phase Shift: 0-180°
Damping factor: >400 @ 20Hz/4 ohms
Frequency response: 15-250 Hz
Dimensions: 19-3/4"L x 10-11/16"W x 2-1/8"H
0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website (SonicElectronix.com) when purchased together with this amplifier.
Authorized Internet Dealer
1-year Manufacturer's warranty
i understand , but you could have just used the original post about an amp,instead of making a new one.if you want a good amp 150-200 will not get a god one ,it will get you a shltty amp or crappy one at best.
RoYALbLUE08
RoYALbLUE08
NYC
RoYALbLUE08
