good amp for 1 type r
what would be a good amp for a single 10" type r?, i plan to run it in a small ported box
and i havent played with the type r's that muhc so i donno what they can and cant handle
thanks
How small of a ported box are we talking about?
1559 useless posts....
i donno, ive pretty much pulled out of CA stuff so just a cheap one from sonixelectroincs
hell no!!!!!
Build one yourself....pre fabs **** a$$
I'd say 1.5ft^3 to 2^ft3 tuned at 32-35Hz.
try to give it 600-750w RMS.
What voice coil configuration is it,Dual 4 or Dual 2?
If it's dual 4 ohm vc's then you can wire in parallel to get 2 ohms so you'll need a 2 ohm stable amp and if it is a Dual 2 ohm vc then you can wire it in parallel for a 1 ohm load or in series for a 4 ohm load so you would need an amp that can give it sufficient power at either 1 ohm or 4 ohms.
im not that dumb i know that.........and no i dont have the sub yet, just want to buy the sub and amp together
4runnercrazy
Mattchu
4runnercrazy
Danville,CA
4runnercrazy
