Good alternative to Sundown??? 2000w rms
If there was an "alternative" to Sundown that was of the same specs at a lower price, people would be all over it.
I agree. But some people buy just for the name. I.E....Fanboys
Sundown is not the ONLY way to go, though some think it is. Im just looking for something a little more in my price range that is till just as dependable and does clean, rated power.
I lucked up on 4 1500Ds a while ago. Before that I had the AQ2200D. NEVER had an issue with it at all. I used it for maybe 8-9 months. I took it out because I changed setups. Price was an issue for me as well at the time. Best deal going IMHO is the AQ3500 for 549. BNIB with a 1 year warranty. But if 12 volt ratings are what sells you on an amp, just save up for the Sundown. You already have the 4 channel so you won't have to go through the bother of finding a matching 4 channel. You could also check DB-r and I saw Jacob post saying that he had a few used 2000s. And though I haven't heard much of anyone using them, DC has a 1, 2, and 3k amp also. May want to look into those too.
Already talkd to Jacob.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The only reason I asked for something that was rated at 12 volts is bc I currently dont have the electrical to support 2000+ watts. Gonna get an XS Power or Kinetik batt after I get the amp. HO Alt is a LONG way down the road.
solid audio f2500d 395 shipped conus
RMS @ 4 Ohm: 700W x 1 Ch.
RMS @ 2 Ohm: 1300W x 1 Ch.
RMS @ 1 Ohm: 2500W x 1 Ch.
been clamped at 3700 at 1ohm at 14v
RMS @ 1 Ohm: 4000W x 1 Ch. @18V
Signal to Noise Ratio: >100dB
THD (IHF-A): 0.2%
Input Sensitivity: 0.15V – 5V
Input Impedance: 47KOhm
Slew Rate: 10V/USec
Damping Factor: 300 @ 4 Ohm
Fuse Rating: EXTERNAL 200A Fuse
Dimensions (in mm):
Width: 240mm
Height: 61mm
Length: 570mm Features
MOSFET Power Supply Amplifier.
Double Sided Through Hole Epoxy PCB.
Gold-plated Brass Set Screw Terminals.
24dB/Oct. Crossover - Variable Low Pass Crossover (40Hz ~ 200Hz)
Variable 24dB/Oct. Subsonic Filter 10Hz ~ 70Hz
Variable Phase Shift
5 Way Protections
Daisy Chain Through Output RCA
Bass Remote Control
Power/Protection LED
1 Ohm Stable Circuits
Soft Start/Output Relay
18V Operation
Parallel Operation
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
Hey there I've had this Axxera AV7336MB for years now, but it's got some issues and needs to be replaced. I went to go buy a new one, only to...
Have you browsed the Audio Control DSPs, like the DM608?
I love my m25 tweeters and will likely try the tm65mkiv or tm8 next.
Plottin4success
Plottin4success
In a kitchen, Louisiana
Plottin4success
    May 18, 2024
    May 18, 2024
