Going Infinite Baffle, What 15 or 18 is good?
Look for something with a Qts higher than ~.5 or so and a low Fs (lower than about 28hz). Those two things will help you find a woofer that will get low and should sound very nice.
The Qts value of the sub will be your Qtc value and it will be the alignment that you will be left with if it is a true IB system.
he said higher than .5 man. but that fs is right.
is that the aura one?
but then again, the idq has a qts of .25 and a fs of 20hz. so it might work well. those numbers are just rules of thumb that make any driver sutible for this application.
Q series from Fi. Scott will make adjustments to them so that they are perfect IB drivers. He as done this for numerous HT guys. You can also get a killer deal on four of them.
JP
what about a qts of .37 and a Fs of 20hz?
It can work, just like the IDQs and it will probably get pretty low with that Fs. What subs are you looking at? Other parameters do matter as well and just looking at Qts and Fs is kind of over generalizing.
Aura Sound
NS15-992-4A
Nominal Diameter . . . . . . . . . . . . . . .15 inches (393 mm)
Nominal Impedance (Z) . . . . . . . . . . 4 Ohms
Sensitivity, 1W/1m (E) . . . . . . . . . . . 86 dB @ 100 Hz
Power Capacity, RMS (Pe) . . . . . . . . 800 W
Power Capacity, Peak . . . . . . . . . . . 3200 W
Frequency Range (-10dB) . . . . . . . . Fo - 1.5 kHz
Minimum Impedance . . . . . . . . . . . . 5 ohms
Voice Coil Diameter . . . . . . . . . . . . . 99.2 mm
Voice Coil Winding Length (h) . . . . . 25.4 mm
Voice Coil Number of Layers (n) . . . . 1
Voice Coil Former Material . . . . . . . . Glass composite
Voice Coil Wire Composition . . . . . . Aluminum Ribbon
Magnetic Material . . . . . . . . . . . . . . Neodymium radial
Stray Flux Shielding . . . . . . . . . . . . . Inherent
Magnetic Gap Depth (He) . . . . . . . . 50.8 mm
Cone Material . . . . . . . . . . . . . . . . . Aluminum
Surround Material . . . . . . . . . . . . . . Injecton molded rubber
Polarity, Outward Motion . . . . . . . . . Positive voltage on (+) terminal
Net Weight . . . . . . . . . . . . . . . . . . . . 20.1 kg
Thiele / Small Parameters
Resonant Frequency (Fo) - Fs . . . . . 20 Hertz
Voice Coil DC Resistance - Re . . . . . 3.3 ohms
Total Q - Qts . . . . . . . . . . . . . . . . . . 0.37
Mechanical Q - Qms . . . . . . . . . . . . 8.0
Electrical Q - Qes . . . . . . . . . . . . . . 0.40
Equivalent Volume of Air - Vas . . . . . 169 L
Radiating Piston Area - Sd . . . . . . . . 765 cm 2
Electrical / Mechanical Parameters
Flux Density x Length - BL . . . . . . . . 18 Tesla-meters
Compliance - Cms . . . . . . . . . . . . . . 206 mm/N
Total Mass - Mms . . . . . . . . . . . . . . 314 grams
Impedance
Frequency Response (1W, 1m)
Maximum Excursion . . . . . . . . . . . . . 75 mm peak to peak
Xmax . . . . . . . . . . . . . . . . . . . . . . . . 38 mm peak to peak
Distortion (1W, 1m)
I purchased one last night, read a ton of reviews and have yet to find anything negative about them, these ar used in Wilson Audio cabs
Aura Sound
NS15-992-4A
Impedance
Distortion (1W, 1m)
Those will work very well in IB. Xmax is also a concern. You will want a lot of linear travel to get useable output.//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
5 Or better is a rule of thumb but way off from necessity when doing IB. When placed in the vehicle the final system Q will raise dramatically.
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
maybe bad amps. I would purchase a decent amp off of Amazon. They usually arrive in 2 days if you have "Prime." If the problem persists, you can...
Now you're annoying me because you are attacking me personally without addressing anything I've said. Show me a single post I've made that's...
20
4K
Dtour
Addicted to sound
Dtour
Virginia Beach
IamDeMan
    May 12, 2024
Brendon Jenness
    May 11, 2024
