Going from 2 to 1 ohm
well i heard from a few people that the soundstorm and performance tekique sucked.. personally i've owned a performance teknique for a while and never had probs with it..
Performance Tecknique amps are good, I have owned one before, but the Headunits are just Alpine rip offs. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I'll clarify.
1 15" 4 ohm SVC sub can only be wired one way to the amp....4 ohms
2 15" 4 ohm SVC subs can be wired two ways...either series to present a 8 ohms load or parallel to present a 2 ohm load
3 15" 4 ohm SVC subs can be wired to present a 1.34 ohm load.
If you want to present the amp with a 1 ohm load then you will need 4 15" 4 ohm SVC subs or Two 4 ohm DVC subs.
Check for yourself....
http://www.crutchfieldadvisor.com/ISEO-rgbtcspd/learningcenter/car/subwoofers_wiring.html
Mr Bojangles
Bullhockey
Mr Bojangles
H'burg MS
BassApocalypse
