Going active
if i want to amp ALL speakers, front and back, will i need another amp since the 4 channel i have will be tied up with the tweets and mid?
What does this have to do with going active?
2way component up front and coax in the rear
Again...active, really?
so i guess my rears will have to go back on the HU. I dont have room for another amp, although i have another one
Sure, you could do that...
also...i have a clarion equalizer coming. would that be good for the CROSS-OVER portion?
Um, WHICH Clarion EQ? I doubt it though because it's an EQ not a crossover, at least it is going by your vague description.
bass_lover1, what kind of a crossover would you recommend if someone want to do 3way active in the front?? cause in my case i wanna keep the stock HU
You want to keep the OEM headunit and do a 3-way active front setup? Audison BitOne.1 is the only thing that comes to mind, but they aren't cheap. But it's the only all-in-one unit that will offer you the processing you need to tackle a job like that.
Yea, that's 99% EQ and 1% Crossover. The 1% is ONLY a low pass for the sub out. Looks like you've got some more research to do.
kudos for your patience
Theride
Theride
NY
BlackMaxima
