Going active options
My63bug
ETkv9
So I assume that I'm wiring tweeters to two channels one and two putting the filter on high pass
Wiring the mids to channel 3 and 4 putting it on Full Pass
ETkv9
ETkv9
Given these crossover options it doesn't matter if the tweeters go on channels 1+2 or 3+4, so that's fine. I see "H.U. 80prs" in your signature. Are you setting the filters on the head unit?
I'm trying to. I need a step by step LOL. Jeffdachef
Your image posts need to go directly to the file name. If you're on a computer you need to right click on the image and select "copy image address". On a mobile device press and hold on the image and then do the same.
Y9SsAR3.jpg%20
Review this in the car so you know what you're controlling on the HU first.
As for crossover slope, which you must select, using 24 dB/octave at all times is generally the safest way to start. It cuts power rapidly above or below the crossover frequency, which is good for protecting the tweeters and for saving the mids from popping due to bass.
GENERALLY SAFE SETTINGS FOR 6.5" MIDS AND 1" TWEETERS
MIDS HPF 80 Hz, LPF 3,000 Hz
TWEETERS HPF 3,000 Hz
Subwoofer LPF 60 Hz - the gap between sub and mids is assuming you want the bass louder and will want some good "bump", yet you want to try to get that SQ "bass up front"
Dial in a high pass filter on the tweeter channels of the amplifier as a back-up protection in case you lose your settings on the HU. Aiming for 1 kHz or so is fine and won't screw up the sound.
My63bug
My63bug
Vacaville ca
youdoofus
