Glueing Amp to backseat back
Put a piece of wood behind the carpet where your going to mount it, drill the wood, use some of them screws that take allen wrench bits. That should fix you up without the use of glue. The screws should be a lot harder to strip and your amp should be alot harder to steal. You can use the glue if you like putting your carpet back on all neat like or to put your wood on the carpet so it won't fall in the chair.
glue will not work.
find a better way to mount it to the metal seat frame or a wood board placed inside the seat....
my vote is drill the wood board to the inner seat, mount the amp to the board. if you look hard enough you will find screws that are as long as you need.
I'll take pics soon (when the rainstorm will fade) but you'll see what the limits are... they're alot of these
amp is long and need to be real high on the backseat so i'll be able to put it back.
I'll be doing 100% velcro under the amp, then i'll push my box till the amp is trap and can't move. I just need to put something on the box so it doesn't rattle coz of metal/wood.
I was thinking about some dry silicone or the thing you put under the chair so it doesn't scratch the wood floors...
I'm not an idiot, only desesperaded (sp???)
Easy fix:1. Get new gf
2. Get new amp
I'll check into detox when caraudio will be in front of my girlfriend/futur wife as a priority. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
wtf is goop?
It seems to hold ok for now, I put some silicon on the box so the amp ain't hitting wood but silicone when the seat are unfolded.
There's a shitload of velcro and lil donkey glue. It will be pretty easy to remove if needed to
Xprime4
****in' canadian
Xprime4
Quebec, Canada
Xprime4
