- Thread Starter
- #46
My alpine HU goes to 35, and i actually have it set to go that high on my highs. But my doors and tweets still sound clear and crisp at 35, i wouldnt hear distortion if i turned it up to high and have started clipping? So should i reset everything to volume 28?Unfortunately the answer to that is relative to a lot of things in your setup. If you're pushing your subs pretty hard to begin with, a small amount of clipping will do more damage. If your subs aren't being pushed very hard, it will take more clipping to damage them. IMO, you're more likely to run into issues with clipping by turning up your headunit too much, using some kind of bass boost, setting your gains past what the amp is rated at, and voltage drop that causes the amp to dip into clipping.
With that being said, the songs that I remix have so little clipping they won't affect anything. If your clip light keeps coming on, you may be turning up your headunit volume too high and causing clipping (alpine's usually start to clip at volume 30, and headunits that go to volume 60+ tend to clip around 48-49, but that is just a general rule of thumb)
WHAT BATTERY SHOULD I GET, my OEM is shot. I dont really know anything about batts
