GHETTO solution to a heat problem.....
Some computer fans are VERY finicky with the voltage you send them, turn your engine on the *poof*, they're fried.
hook them inline with a small capicator and you should be fine //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
its called the peltier effect (if its what you're reffering to). i considered using it in my setup when i thought it was ground breaking till i learned that condensation could be a problem under the plexi and false floor.
i am currently trying to figure out how to direct the rear passenger a/c to the amps instead. here are some links regarding it though. the first one has the fans and such that were mentioned above. If you use it, let me know how it works out.
http://www.tetech.com/assys/air.shtml
http://www.peltier-info.com/photos.html
http://www.digit-life.com/articles/peltiercoolers/
Yep, thats what I ended up doing after I fried 2 of em right away //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
No big deal tho, my dad had a bunch that he ordered but didnt fit the cases he had, so he just gave em to me //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Oh man, that's like s3x with your mother in an elevator, wrong on every level!
27
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
Are there any label making machines available that allow you to print directly on your currently owned heat shrink and not from a manufacturer...
Any air movement is helpful in keeping any amplifier running cooler as long as there is a way to release the heat build up. I install all my amps...
Upside down should be fine. Airflow is all that matters. My buddy did this install. I think 14 amps. Look at that sloppy wiring. 😂 Vegas don't play.
4
BassAddictJ
BassAddictJ
FL
jujumantb
Decebal
    Jun 10, 2024
