getting the most seminal fluid possible
Also to OP, jack it once or twice a week instead of everyday. Also the longer it takes you to ***, the more 'liquid' it will be and the greater chance of cumming buckets.
yea when i want to go a lot to see my potential i stray from the jerkin for at least 3 days but i do tend to ********** a lot normally. I've been looking into how long is necessary to wait before you *** and i havn't figured that one out yet. So the sperm which are roughly 5% of the *** start into the epididymis and go into the vas deferens, now that loops up through the body up and over the bladder to warm up the sperm or w/e, so is that process slow like a capillary action? Lets say that takes 10 minutes to move enough sperm through the tube, and as it reaches the end and passes by the seminal vesicles 60% of the fluid is added to the sperm and then it reaches the prostate gland where 30% more is added other 5% is considered precum? From what i read it says the final product semen is stored in the urethra before ejaculation? Is that part true or any of what i just said lol, cause if it is then i just gotta get a bigger dick to *** more so i got more urethra to store it? Oh yea and how much can stress really effect your testosterone levels and such wouldn't that play a big role on each of the different fluid levels in the semen? And lets say you change your diet and start making 20% more seminal fluid how does the prostate fluid equalize the ratio does it just not and keep making that same 30% so you end up with 20% more fluid altogether?
Ejaculate into your own mouth but don't swallow it. You have to let it absorb in your mouth (absorb anywhere internally really, but stomach acid will break it down) and your body will send it to be ejaculated again resulting in more semen.
I got into this for a little while too and my girlfriend didn't care for it much either but it was just cool to me...lol. Celery actually helps, as well as, Tribulus Tirrestris (sp?) helps with weight lifting too, ZMA (test booster) also helps lifting, but some other stuff I've taken to help specifically for that is, Ball Refill stacked with Chainsaw by Vigor Labs, and Horny Goat Weed, drinking a lot of water. Also try not to ********** as much, if you get to the point of cumming hold back for a minute and then go again, that usually helps. I read that Life-flo Maca also works well. Try not to take too much Yohimbi which is in a lot of products because it does cause headaches, if you do take a lot of it drink plenty of water. Argenine is good and is in most of those supplements, not sure about the Lysine though.
Yes, this is the best way
You must proceed to give yourself Blue balls on a daily basis. It's only a short-term soulution but it will trick your body into reloading. The swelling also helps increase seminal capacity. Should work like a champ!
No, Proximity had it correct. You must ejaculate into your mouth and hold it, let it absorb. He forgot to mention gargling for that added effect. Works every time!!
Hydrastas
Hydrastas
NE ks
Ignatowski
