getting a thump when car is started
swangin68
ok i searched for days and i really cant find a solid answer or even a realistic possibility..ok,, i installed in a scion xb a LOC with a sub amp and 1 12" type r. it was working just fine for a while, then one day i decided to try a more powerful amp so i pulled that one out and put in another one,,, also i might have grounded the remote wire on the amp, i seen it touching it and i might have had the key on dont rememeber...so if it had juice i might have messed something up in the HU...now it thumps for a good 1 solid second when u start the car... if the key is off and u straight start it it wont thump, but if u click the acc on and let the amp turn on and radio, then start it. it thumps. like it dosent fully turn off anymore as the starter is turning over...
i have the remote wire to the acc fuse i think, i forgot what fuse exactly but it worked fine.. the fuse was not popped either,, still works just thumps now...for like as long as u hold the key to start thats how long it bumps.....
its annoying me,, should i switch the remote wire and tap it to the radio switch or the lighter or something.. i hope i didnt damage anything.. also its not the amp i checked it and its fine.. im pretty sure its the remote from the car....
ground is to the battery....its good... like i said it was fine for a while then i tried another amp then put the original back and now its there, didnt change anything...
Find the remote to the head unit and try switching to that. Cant hurt and might help. DId that on my sons car and got rid of the amp pop.
If the loc has a ground wire on it try grounding it also try running a ground wire from your factory radio harness to the ground input of the amp.
havent tried grounding the rca,,, how u do that? also the loc does have a ground connection which has never been hooked up. but if these choices were the case wouldnt it have always done it? these 2 things were never done so why would that change now....???
swangin68
swangin68
hemet ca
91Chevy
AJ (ACE)
    Jun 28, 2026
