Gettin 1/0 Gauge into Distro
I finally got it in there. Now i'm trying to get it into my 1/0 ring terminal.. having problems with it too.
What's the best way to strip the wire??
there imight be a fitting insiide the 0 guage terminal that reduces it to 4 or 2, remove it.
pay very close attention to the qouted post, I'm almost willing to guarentee this is the problem if you really can't get it.
It's pretty tough to make out that there are inserts but it's the case i'm sure.
It's not hard at all. I just get one side in, then squeeze the other half onto the side that is already in, then with it squeezed with a couple fingers carefully insert into the distro/ring connector.
It is a tight fit, but it will work.
I also squeeze the hell out of the wire before inserting it to make it as compact as possible.
Here is a pic, Kolossus in ring terminal before crimping.
Just strip very carefully. You can use like a razor blade or something. Just keep the wires very neat after you strip it, then stick in right in, while squeezing the ends together a little bit.
I'm using the Kollosus 1/0 gauge wire. I think I just need to strip more carefully.. my wire keeps on turning into a "mushroom" type thing, and it won't fit at all.
Dude look at my pic above, that is 1/0 gauge Kolossus and it fits fine, you just need to squeeze it in there, no cutting off wire is required.
TacoSauce
TacoSauce
Orlando
Big Dee
