******geo Metro Wall Build ******
Finished up the driver side piece just to cover the gap until i get the beauty piece done. Still having some issues with the rear windows trying to pull the bolt trough the window. But as soon as the beauty panel is on an sealed it should not be a problem anymore.
Nice wood work.
//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif for a metro
Wondering where the wall itself is held in, hopefully more than just that 2x4 //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif.
Vidssssszzz
Ok then 11 cubes will be fine. Keep in mind the f/s of those woofers is about 28 hz, so you if you tune really high above that, the woofers can...
What would you recommend using for the roof then ? Should I do just the bpillar or the whole roof ?
913
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
These are the tweeters in going to use in my truck. Beefy little guys just going by weight. Probably not the best for a car audio setup, but I'll...
63
8K
JBLCAMRY
KCB
JBLCAMRY
239, Florida
BoomTaco64
