General setup question
lastdecibel
I was wondering what the best way to go about setting up everything once I have everything I need. Not trying to go all out, just want a well rounded sound stage with SQ way over SPL. I have one 12" MoMo svc plan on adding another 12" maybe Infinity. I also have some 6.5" Kicker Components that hold 75 RMS and 150 peak. Most likely I am going to get the Cadence TXA6004 to juice it all. How should I wire all this for best efficiency?
While I am no audio expert by any means, I think I have read on here that you shouldn't mix brands of subs. Stick with the same through-out.
How about using 2 channels of the amp to power the components and then bridge the other 2 to power a sub?
No ****ing reply? I love the way all these mobile audio audio experts on this forum dont say shit. ****ing worthless
7 posts and this is how you act? mix subs and run that amp on those comps. you will be happy as can be. make sure you have the gains turned all the way up on the amp to get the most out of it.
How about I bridge all the channels to the sub? Sounds like a good idea
Thanks pinkfloyd for your input. That's what I was thinking but just not sure if I should add another sub. That was the original plan just running one sub but have a niche to add another. I'm not looking to to be heard from a mile away but just want the music to sound good during the ride.
OP: its not very nice to disrespect a whole forum and then expect us to help you. I think the first thing you want to do is search the forum to see if your question has been asked before because it probably has and been answered already.
I always search the forum before I even register. If I find the answer I am looking for I sometimes don't register unless I think there is a wealth of knowledge that I can gain form the members. So since I couldn't find my answer, I joined the forum to post a thread and get some feedback to a personalized question. However the 2 threads that I posted seem to be getting a lot of views but not responses. Then I looked further at some other threads a had seen that they too have hundreds of views with as little as 7 replies. Just erked me a bit to see that. Other forums that I am with provide a lot of feedback, sometimes wrong, but tons of feedback none the less. That's all.
If you say you want SQ not SPL then spend more money on your comps and not on your subs.
Get the best comps you can afford, power them off an amp with plenty of power. Deaden and seal your doors well. Install the comps well and the single 12" with a decent amp will give you the best SQ for your money. Wire the Big3.
Look at other threads on here to see how others have installed thier comps and power.
I was going to get the momo 6501 or image dynamics ctx65cs but I got a ridiculous deal on the kickers that I couldn't pass up. The budget supersedes SQ unfortunately. Another problem I have is that I dont have the tools to build my box and looking at a prefab box. It's hard to find a box to fit the single 12 Momo. Found plenty that house dual 12".
Thanks for all the feedback.
lastdecibel
lastdecibel
Austin, Tx
lastdecibel
