Gain setting... not the usual question
jdawg90
I have a 18" D1 BL that is .75 ohm dcr per coil... i am buying a zx1500.1 in a couple hours and am not sure how to set the gain... should i set it using 1.5 ohm as the resistance or 2 ohms? THere is a big difference in the voltage output between those two (47v vs. 55v)... im leaning towards 2 ohm because it will probably be at that after rise, but i just want a second opinion... what im worried about in the frequency range there is little impendence rise the amp might clip....
thanks
jdawg90
jdawg90
alberta
Enellz
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
