TrlcKed_OuT
plz someone tell me the correct way to do this....i have them strapped pushin 2 12''sx at a 2ohm load.....
jeez man... hostility. calm down there are like tons of posts goin on each minute. if noone answers my topic, i say to myself, its easily answered, and use the search button.CMON GUYS CANT NE ONE EVEN LOOK AT 1 ****IN POST I MAKE THIS PLACE BLOWS!!!! i guess if im not acid or jmac or lemans no one gives a shit eh???
ok i have no idea how u just got that.... i thought u set ur gains for the output volts on ur hu...ex- u gotta use volts=sr(powerxresistence) that would meanThats right! //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
This is an animated guide to ensuring your gains are safely set
http://www.jlaudio.com/tutorials/Input_Sensitivity/Input_Sensitivity.html
You basically set the output voltage on the amp to the rms voltage handling of the sub.
You're sub the SX can handle 1000watts RMS and has 2 2ohm coils
1000watts at 4ohms equals(coils in series) 62volts handling
For a pair of them wired for a 2ohm load to the amp you have a voltage handling of 63.24 volts.
So watch the guide then go for around 65volts for a gain setting.
If the amps are strapped to work as one then you want the 65+ volts, if you just settting one you want 33+ volts. There is a way to convert wattage into voltage using wattage multiplied by ohms then find the square root of the result gives you a speakers voltage handling at a given ohm. For amps it opposite, voltage squared divided by ohms.ok i have no idea how u just got that.... i thought u set ur gains for the output volts on ur hu...ex- u gotta use volts=sr(powerxresistence) that would meanvolts = sr(2400x2)69.3 or would i do it volts=sr(1200x1)=34.6.....its 2 amps so do i set them like the were combined like the first or do i do it for just one and it tranfers to the other and evens out...i have no clue where u see ne thing about matching volts form subs or whatever in the gain setting sticky......
