Gain is relative to volume
gain is volume..
You set the gain based on the volume.. you can max the amp before clipping at volume 1 on your h.u if you wanted..
think of it like using an aux cord for an ipod.. you can start clipping on the h.u before much noise is coming out if you set the ipod volume low and vice versa
the gain is a potentiometer, you set the amps input voltage to your headunits output voltage using it. Just using the gain as a volume knob is a good way to ruin your equipment, sound like shit, and be a retard.
I am saying it is only relative to HU volume. That you can set your gain to max as long as you don't turn your HU volume up too loud.
This is true, but it defeats the purpose of paying for a high voltage HU. The idea is to get the strongest signal you can into the amp allowing you to run the gain as low as possible and still get the expected power out of the amp.
A lot of bad things could happen if things are set up the way you suggest -- One, your idiot buddy grabs the volume and cranks it and torches all your speakers. Two, there are some 5v+ hu's, and amps with sensitity as low as 0.125v. With the gain maxed out in a situation like that you'd probably have clipping in the bottom 10% of the HU's volume range, not to mention you wouldn't HAVE any volume range. You'd have off, loud, and clipping.
Alpine4life89
Alpine4life89
missouri
n2audio
