Really stumped here.
I was getting a buzzing noise (especially on lower fq like 500-100hz) from the woofers. I wired the woofers to my other amp (I run 2, 4ch amps) and the sound became clear again, so I figured it was the amp. But then I tried two other, perfectly working amps, with the original ground and power wires and the buzzing came back.
So I excluded the amp as the culprit.
I used those same ground and power wires and ran them to the amp that I wasn't having issues with and the sound was perfect, so it's not the ground or power wire either! And it's not the speakers!
WTH? I'm going nuts here. I'm grounded to the metal floor - I drilled a hole and then wire brushed around it, clean as a mirror. I've grounded both amps to this spot - the ground wires are 6" and 8" long, so very short. Both amps are not touching any metal, either with rubber isolators or a carpeted sheet of thin plywood.
Both power wires come from a distribution block at the battery. I thought maybe a low battery, but why would speakers from only one amp have issues?
Neither amp is being run that hard, gains are down. BTW, the buzzing happens with the engine off, gain turned all the way down or not, and it's only one with sound. So if there's silence in the music, there's no buzzing (like a ground loop) - only when sound and most notable in vocals. I have no alternator whine. There's no real white noise when speakers are on, music playing, but volume to 0.
No frayed wires or poor strip jobs on any of the wire. Fuses aren't blown. Seriously I can't think of anything else. Can't be the RCAs because they're (3) routed the exact same and they work for the other speakers. Not the headunit by that same logic.
What do you guys think?
Has anyone heard buzzing from a good speaker and only with sound/vocals?
The subwoofer isn't super far from the amp who's speakers are in question, maybe 18 inches - is the magnet creating a field of something? lol Why is there always a problem!! //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
