Fuses? Yes or no?
That's an exaggeration. In all honesty, something has to physically be damage in order for system to get over-powered... like if the wire got grounded. Then it'd catch on fire... but, I mean, most people just won't ever blow their fuse. But, like said... i'ts better safe than sorry. We're talking about your X-thousand dollar car with your X-hundred/thousand dollar system.
that is what the fuse is for in case it gets grounded. The main fuse on the wire is for the wire protection in commercial electrical. Then a circuit breaker or fuse before a load to protect that. Take the battery cable and ground it, that is what can and may happen to your car if you run with no fuse. I have seen to much equipment burn up even when protected just because breakers and contacts have welded due to loads grounding. Fuses are just a safe simple bet, 5 dollars to keep the fire away
Alright I made a diagram. With all the green being fuses. Does it look right?
That's right. why bump it? You drew it correctly. You always fuse at the amp (unless the amp has it's own fuse) and at every source of power as close to the source as possible - which is each battery, just like you have drawn.
Yep.
I wont lie though, I dont have a fuse in before my batt that I have in the rear. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
But I should put one in.
Yep.
//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
mazzasec
Banned
mazzasec
ATL
MikeyB
