fuses and wires
From battery to battery, 1/0 with 300a fuse is a must.
From battery to amp, depends on the amp. You can figure that out by what size wire the amp accepts. If it accepts 4 gauge wire, the use 4 gauge and a 125a fuse. If it is 8 gauge then 8 gauge wire and 50a fuse.
Always choose your fuses by the rating of your wire. If your wire is rated at 300a, use a 300a fuse. NEVER use a fuse larger than the rating of the wire.
knu rates their 1/0 at 250a so with rating on wire i will need two 250a fuses.
my dd m3 has 1/0 inputs as well so once again another 250a fuse right?
also i have heard rate fuses on the amp when coming off the battery. anyone know the fuse rating on a dd m3? or stick with 250a?
knu rates their 1/0 at 250a so with rating on wire i will need two 250a fuses. my dd m3 has 1/0 inputs as well so once again another 250a fuse right?
Cool, so it is 250a for your wire. Stick with a 250a fuse all around and all is good.
ezekial130
ezekial130
Indianapolis, Indiana
loopkiller
