Fused or unfused Distrobution block?
fused block for power wire, non fused for ground usually.
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
If you are fused at the battery and your amp has on-board fuses, then you're good to go:)
your fuse has to do with your wires capacity as well //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...not just the amp.
I doubt your running 0 ga wire straight into your amp so do like me and invest in the fused distro for 30 bucks. Oga from batt to 3 4ga which go each to an amp. Yes amps are fused but its nicer to know having a 50 cent fuse b4 all your expensive amps can save you alot of headache. Just be sure and follow the rule whenever you go smaller in wire size add a fuse.
ebayed that badbay for about 30 bucks
http://www.darvex.com/miva/merchant.mvc?Screen=PROD&Product_Code=SXFD04&Product_Count=1
Shit you can find a fused distro...1 1/0 in 2 4awg out for like 10-15 shipped //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Fused power, Unfused Ground block
Yes you do need it. the only way you wouldnt get one is if you were running straight from the battery > fuse > amp
If you're in a distro block of any type FUSE IT before reducing to a smaller size wire
kpozr2
kpozr2
Iowa CIty, IA
Ruffy
