Fused/Nonfused
a fuse is needed whereever wire guage changes
not true. there is no need fuse a wire just because the wire changes size.
Fuses are not meant to protect the amps unless the amps do not have their own fuses. The fuses in the power wiring are there to protect the wire and thus the car in the event of a short in the wire.
this is true. matter of fact right on the money. now what you do need to consider is, is your main wire coming from the battery big enough for the amps you are attempting to run? for example the first amp may be 80amps and the second maybe 80 amps too that's a total of 160 amps and for that i would recommend stepping up the main run to the next size up.
Fender5
Fender5
Arkansas
helotaxi
