Fused/Nonfused
The only time you would need a fused distro is if you are running a fuse on the main power wire going into the distro that is larger than the rated capacity of the smaller wire coming form the distro. For example you run 1/0 from the battery and fuse with a 250A fuse and your wire from the distro is 4ga which is not rated for 250A and needs to be fused for its rating or less.
Fender5
Fender5
Arkansas
helotaxi
BP1Fanatic
BP1Fanatic
