fuse problem.
150A fuse is perfect.
Edit: If your running both amps off that power wire and I assume your doing a distro block with 2 4 gauge runs?
i didnt put in the distro block yet ..
also would a 200a fuse hold up better and longer?
be less stress on the fuse?
i only have 1 4guage wire pushing all the power.
Get that 1 gauge kit in with the 150 amp fuse ASAP, and you shouldn't have anymore trouble. 1 run of 4 gauge can't properly power those amps.
You really don't need a 200 amp fuse, but incase you ever upgrade your amplifiers, you might want to keep a 200 or larger around.
daicacharco
daicacharco
San Diego. CA
daicacharco
