Full Range to jl cleansweep?
alfisti
cl441dsp cleansweep requires full-range signals but the **** CL-SSI and lc6 is a bit expensive:( Car has seperate tweeters in front door so I need a cl-ssi right? Is there a cheaper way to solve this problem?
For temporary can I use the rear outputs of cl441dsp to a mono amp without any summing device?
and cl441dsp has 4 rca outputs, so can I run all rca outputs to a 4channel amp which has 2 rca outputs and from that 2 outputs to mono amps 2 rca inputs?
alfisti
alfisti
Ankara
alfisti
BP1Fanatic
BP1Fanatic
