Full range test tone?
Dont' forget though, your ears wont' hear all tones at the same true volume to be at the same volume. Essentially some frequencies are "louder than others. Meaning if all tones create the same SPL, you'll hear some louder than others. It's a bell curve shape. Meaning it'll start low and quiet, get louder and higher up to a point, then get really high, but quieter again. I guess if you hear any sharp drops it could be a gap in F/R, especially near crossover points.
Urei Sonipulse.... Produces a series of pulses set to different frequencies so that standing waves are not gauged. The reason for doing this is in most music a sine wave is not going to be used, also sound is usually very random. And pink and white also have a tendency of producing very unnatural standing waves in loudspeakers systems. So if you can find a UREI Sonipulse 100-A you will be set....
Problem is you can't find one. So use a sine sweep or White/Pink noise... Most of all just use your ear. If it sounds good to you then nothing needs to be done.
Did you ever get the issue with yours figured out??
ultimate157
Engineering Student
ultimate157
Worcester, ma
T3mpest
vegang
vegang
