Full range signal to feed mono subwoofer amp
You guys are awesome! Im so happy I joined this site, everyone has been so helpful!
Without you guys I don't think my build would be going very smooth. From the questions I have asked and just reading around, I have learned so much!
//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif//content.invisioncic.com/y282845/emoticons/happydance.gif.a963168fea27d8453c3ec467ddcf9e1c.gif
[quote name='quackhead']@Team Maxxsonics
Why would you recommend against using the RCA L/R full range stereo inputs on a monblock?[/QUOTE]
Because Maxxsonics mono block amplifiers are probably the only ones crippled by their design and are unable to accept stereo signal and then add the left and right. You have to take one channel and split it with the y-splitter. This is a reason why I returned a new MB Quart ONX1000D and why I will never buy an amplifier with such design.
a ton of amps only have one input.
Perhaps, but that doesn't seem to be optimal since many stereos have a separate left and right out. The Maxxsonics amps do have two inputs, but require the same signal on both. In fact, a single input would have worked better, however suboptimal, because then there is no need for the y-splitter. In the end, I am not concerned with the y-splitter, but with the possibility that if the left and right signal is not the same, then this setup alters the recorded signal.
Seems like something as important as this design would be outlined in bold letters in the specs. Which HU's have 1 single mono out, or two that are not color designated? What other Amp manufacturers follow this design pattern, besides the ones with a single rca input?
Ok! So from all that, my monoblock amp has a input of L/R RCA connecters that are white and red. That means I can use the full range signal to feed it?
butterMilk
butterMilk
BC
butterMilk
