Full guide: How to Copy/Rip DVD and Convert Video on OS X
queen789
Are you a Mac User?
Do you want to make a copy of your DVD to share it with your friend?
Do you want to rip your DVD to play it on your portable devices?
Do you want to convert your video to your iPod/iPhone/Zune/Mobile Phone/PSP/iRiver/Sansa?
This guide is a full solution to solve all the questions above.
It includes three parts.
Part 1: How to Rip your DVD with Wondershare DVD Ripper for Mac
Part 2: How to Copy your DVD with iSkysoft DVD Copy for Mac
Part 3: How to Convert your video with iSkysoft Video Converter for Mac
Step1: Install and run Wondershare DVD Ripper for Mac(Inter PC Users) or (Power PC Users)
Step2: Import DVD Movies
Click the “Load DVD”button to load your DVD or ISO.
Step 3: Output Settings
After your DVD movie is loaded, you can start to set output settings:
1. Select an encoder type from the format drop-down list according to the device you want to put the video on.
2. Click the “Settings” button to set the video and audio parameters.
3. Name each title/chapter in the “Output Filename” field, and select the suitable subtitle and audio track for the titles/chapters if you want.
Step 4: Click the Start button to start the conversion.
All you need to do now is to wait for the conversion to be finished. The remaining time will be shown on conversion window for your reference.
You can edit your DVD by using the powerful functions. You can use “Trim” to cut any clip your DVD and use “Crop”to cut the black edge of your DVD.
Step 0: Download iSkysoft Video Converter for Mac (Intel Version or Power PC Version),install and run it.
Step 1. Click “Add Files” button to add the video you want to convert. As this iskysoft video converter supports batch conversion, you can add several videos and convert at one time.
Step 2. you can convert your video into any other popular video formats by clicking “Format” button. Also, if you want to customize your own settings you can get it by clicking “settings” button next to the “Format”
Step 3. click “convert” to start your convetsion
Some powerful functions such as “Merge”, “Crop”, “Effect”, “Snapshot” are all available.
Step 1.Install and run iSkysoft DVD Copy for Mac (Intel Version or Power PC Version)
Step 2.Select the source DVD and select the DVD Copy Method.
Step3.Choose the output settings.
a.Set the Buffer Dictionary
b.Select the language
Click “ok”, then the setting can be saved
Step4.Copy dvd to dvd disc on Mac
Click the “copy”button and begin to copy source DVD movie to blank DVD disc on Mac OS.
More functons of iSkysoft DVD Copy for Mac:
(1)Copy DVD at 1:1 quality.It can clone DVD (D9 to D9, D5 to D5) with the entire movie in 1:1 ratio perfectly on Mac OS.
(2)Remove DVD protection .iSkysoft DVD Copy for Mac can remove CSS, RC and RCE DVD protections to let you copy & burn DVD movies with no restrictions. (3)Copy DVD golder.It lets you copy the DVD folders of DVD movies to save them on your computer.(4)Directly burn DVD .
queen789
queen789
dstdfs
Twistid
