FT/FS Pioneer GM-d9601
evilmonstertruk
Premium Member
Premium Member
Pioneer GM-d9601Amp
General Features:
GM Digital Series Class D Monoblock Amplifier
RMS Power Rating:
4 ohms: 500 watts x 1 chan.
2 ohms: 800 watts x 1 chan.
1 ohm: 1200 watts x 1 chan.
Max power output: 2400 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
Soft start turn-on
Mono channel operation
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
Preamp RCA outputs to daisy chain multiple amps
3-way protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy heat-sink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable low-pass filter (40-240 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 10-240 Hz
4 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier.
Dimensions: 12-3/8"W x 7-7/8"D x 2-3/8"H
In great condition. Only a few months old. Bought it in May from amazon.
Its a great amp, never gets hot, actually it barely gets warm. I blew up like three different subwoofer because of the two ohm power. One JL 12w3v2, a Type R and a crappy old MTX . Currently pushing a Eclipse SW at two ohms.
Looking for a comparable mono amp with a subsonic filter or cash
Trying to add pics but its keeps failing. Gonna try from computer later
Textme 2404662119
Josh
120.00 shipping included unless crazy far away
Included if it's crazy far away might add a couple bucks
View attachment 26550239View attachment 26550240Item(s) for Sale:
Thank you
Definitely not kidding when he says this thing doesn't get hot. I ran one of these at 1ohm all day long and it never got warm. Even being pushed up against a seat. GLWS man.
Looking over the pics, there are some minor scratches so Ill knock it down to 120.00. But im really looking for a trade. Need a comparible two channel or mono amp with a subsonic filter.
I took my Eclipse out on Saturday to put into a box I was making. So I put my type r in my car as a temp and this morning on the way to work the type r started smoking.. My gains were set by a DD1 so I knew they were correct.
This amp takes another victim
evilmonstertruk
Premium Member
Premium Member
evilmonstertruk
Maryland
evilmonstertruk
