Sold FS: Zed Audio Deuce w/ Burr Brown - $300
sundownz
Pro Seller
Supporting Vendor
400w x 2 at 2 ohm
200w x 2 at 4 ohm
245w x 2 Typical Output Power at 4 ohm (0.8% THD)
800w x 1 Output Power bridged into 4 ohm
400w x 1 Output Power bridged into 8 ohm
Fuse: External 60A for 4 Ohm loads, 80A for 2 Ohm loads
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
NO TRADES - Do not PM me with "What is the lowest you will take" - MAKE AN OFFER if you have one.
how would this compare to audison?
these are handmade in the US, the higher end Audisons are hand made in Italy. For the price this is a great amp. Ive wanted to try one for a while but my next build is pre determined.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i wouldn't mind trying this amp, but only if its as clear as my audison. The zed def. puts out more power, but i would rather have more clarity than loud in this case
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
the clarity would be install dependent, both of these amps would do the job very well, the extra power may come in handy down the line;)
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifthe clarity would be install dependent, both of these amps would do the job very well, the extra power may come in handy down the line;)
components, not subs. i tried three amps with the comps in the same place, and there was night and day differences between the amps with these speakers.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
