Sold FS: used JBL BPX2200.1
stupify
2200-Watt Parallel/Bridge Subwoofer Amplifier
2200-Watt Parallel/Bridge Subwoofer Amplifier with Dynamic Bass Optimization Circuit.
Unlike conventional mono subwoofer amplifiers that only deliver their maximum power into a single impedance, the BPX1100.1 and BPX2200.1 are two-channel amplifiers that can be bridged to deliver double the voltage of a single channel into impedances between 2 and 4 ohms. The two channels can also be connected in parallel - that''s right, parallel - to provide double the current of single channel into impedance below 2 ohms. This feature is patented and unprecidented in car audio amplification. Thanks Crown!
Slope-selectable variable electronic crossovers - Both the BPX1100.1 and BPX2200.1 is equipped with a variable electronic crossover capable of setting the slope rate at 12dB or 24dB per octave. The crossover adjustment range is 32Hz - 320Hz.
Dynamic Bass Optimization (DBO) - This provides variable filtering with adjustable "Q" below 100Hz, far beyond conventional "Bass Q" circuits, by allowing the low-frequency output to be optimized for specific subwoofer applications. Frequencies below an enclosure''s tunign frequency can be attenuated, preventing damage to the subwoofer and allowing the amplifier's power to be better utilized.
Both the BPX1100.1 and BPX2200.1 come equipped with a remote bass level control allowing you to optimize bass output for specific music or preferences from the driver's position.
Full-range preamp outputs - In the event that multiple amplifiers are used in an application, this feature allows for streamlined system hookup. No high-loss Y-adapters or splitteres needed.
SPECIFICATIONS
General
CEA Rated
Click here to learn about the new CEA2006 Amplifier Standard.
Power Output 650 watts RMS x 2 channel at 4 ohms
and ≤ 1% THD + N
2450 watts RMS x 1 channel at 4 ohms,
14.4V supply and ≤ 1% THD + N
1810 watts RMS x 1 channel at 1 ohm,
Signal-to-Noise Ratio 67 dBA (reference 1 watt into 4 ohms)
Dynamic Power 2940 watts at 4 ohms
Effective Damping Factor 6.28 at 4 ohms
Frequency Response 22Hz – 302Hz (-3dB)
Maximum Input Signal 7 V
Maximum Sensitivity 250 mV
Output Regulation .12 dB at 4 ohms
Dimensions (H x W x D) 2-9/16" x 21" x 12-1/4"
MSRP U.S. $ $1599.95
I'm located in South Dakota. I'm looking to get $500 plus shipping. The amp does have a couple little scraches etc but nothing super big or anythign that affects the performance of the amp.
I have plenty of references on here, Sounddomain and other boards.
I'm selling because I'm looking at getting a Honda s2000 and I won't need a amp this big any longer.
Please email me at wkathol@gmail.com for fastest response
NO TRADES!!!
This is just a little of the references I have. This isn't getting into ebay or car forums
http://www.sounddomain.com/ubbthreads.php?ubb=showflat&Board=16&Number=969223&Searchpage=1&Main=152670&Words=+Stupify&topic=0&Search=true#Post969223
http://www.sounddomain.com/ubbthreads.php?ubb=showflat&Board=16&Number=975913&Searchpage=1&Main=154370&Words=+Stupify&topic=0&Search=true#Post975913
http://www.sounddomain.com/ubbthreads.php?ubb=showflat&Board=16&Number=975113&Searchpage=1&Main=154158&Words=+Stupify&topic=0&Search=true#Post975113
http://www.sounddomain.com/ubbthreads.php?ubb=showflat&Board=16&Number=973201&Searchpage=1&Main=153620&Words=+Stupify&topic=0&Search=true#Post973201
http://www.sounddomain.com/ubbthreads.php?ubb=showflat&Board=16&Number=972910&Searchpage=1&Main=153565&Words=+Stupify&topic=0&Search=true#Post972910
I've dealt with all these guys from Sounddomain
dreid / Orange Foci
yosef
loud_aurora(x2)
SPLfreak
uiplannerman
Version 13
J37X
SteveC
this_forum_did_me_wrong
professional
Morris
blazedagain
*BowDown*
Goin' Def
its_hey_ma
TheGame420
Split2nd Racing
Renegadesrun
HCCAfan
OkMariner
vitveet(x3)
bigaztec
bkoopman1
vibrator
slow2.2sonoma
skinrock
snoopdan
mattz
http://www.caraudio.com/forum/showthread.php?t=145819
http://www.caraudio.com/forum/showthread.php?t=113112
http://www.caraudio.com/forum/showthread.php?t=111900
http://www.caraudio.com/forum/showthread.php?t=103339
I can get others if really needed
stupify
stupify
South Dakota
stupify
