http://www.usamps.com/old_site/products/inv/us-x3.htm
for those too lazy to open the link...
Three-Way Active Electronic Crossover
Four Channel Input with Six Channel Output
Selectable Three-Way or Two-Way Operation
Nine Volt Outputs with Separate Gain Controls
50Hz-500Hz Variable Low-Pass Output
Variable Mid Range Output with 50Hz-500Hz High-Pass and 500Hz-5KHz Low-Pass
500Hz-5KHz Variable High-Pass Output
Mid Range Phase Inversion Switch
Delayed Amplifier Turn-On Output
Fuse Rating: 3 Amps
Dimensions: (Including Terminals)
32mm / 1.25in High
241mm / 9.5in Wide
165mm / 6.5in Deep
Weight: 0.91kg / 2.0lb
MSRP: $379.99
one identical to mine on ebay...
http://cgi.ebay.com/US-Amps-USX-3-Baddest-Crossover-Made_W0QQitemZ5792839855QQcategoryZ1498QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
hes asking 150+20 shipping as opening bid..
im asking 110 shipped
Fuse Rating: 3 Amps
32mm / 1.25in High
241mm / 9.5in Wide
165mm / 6.5in Deep
MSRP: $379.99
