FS: Two amps
Sub Woofin
(1) Crescendo 1000c4 4 channel
Power (RMS) at 13.8volts:
125w x4 channels at 4 ohms
250w x4 channels at 2 ohms
500w x2 bridged at 4 ohms
250w x2 bridged at 8 ohms
Features and specifications:
4/3/2 Channel Class-AB Bridgeable Amplifier
Optimized PWM Power Supply
Fully stable into 2 ohms stereo and 4 ohms bridged
18db/Octave Variable Crossover Slope High Pass Filter with HPF/FULL/LPF Selection (1 for each stereo channel pair) (50hz to 1khz)
Low Pass Filter with HPF/FULL/LPF Selection (1 for each stereo channel pair) (30hz to 250hz)
Full Comprehensive Multi-way protection Circuitry with Status Light Indicators
Ultra Wide Frequency response: (10hz to 40khz)
Signal to Noise Ratio: >90dB A-Wieghted
Total harmonic Distortion: .05% at 4ohms
Operating Voltage: 9.5V to 16volts
Wired Remote Gain Controller, Blue status light
Fuse Rating: 30A x 3 Parallel delayed
Dimensions:
Inches: 9.7(W) x 2.4(H) x 16.9(L)
mm: 247(W) x 61(H) x 429(L)
(1) Polk Audio 880 Monoblock 800W Class AB. can also be a two channel
Monoblock amplifier for subwoofer use.
300 Watts x 1 (4 Ohm), 500 watts x 1 (2 Ohm). CEA-2006 compliant specifications for true, accurate power ratings.
800 watts x 1 (2 ohm) dynamic power.
2 ohm stable design can drive even the most demanding subwoofers.
Power and ground terminals accept bare wire up to 4 AWG. Terminals use standard #2 Phillips head screwdriver- no more hex wrenches to lose or strip!
High-speed MOSFET switching power supply and high current Bipolar Output Transistors pump maximum voltage and high current to your speakers or subwoofers.
Double Layer Fiberglass Epoxy Printed Circuit Boards for more rigidity, less shrinkage and a smaller overall amp footprint.
6-Way Smart System Protection (SSP) circuits.
Both are used like new condition except the polk has some adhesive stains and scratches. never abused
the amplifiers come with their respected wired remotes. the Polk also comes with the allen wrenches and speaker level inputs.
Crescendo: $160 shipped
Polk: $80 shipped
prices are negotiable, just shoot me a PM!
Paypal preferred. Usps
Sub Woofin
Sub Woofin
California
Sub Woofin
Mike Mccabe
