fs two 4" Aero Ports
  • 5
tc3k101
Ω
9,496
17
Socal
Two 4" Aero ports
Used both 15" long tip to tip both in the inner flare have chips on the outer part of the tip. I believe I have extra tips and couplers but not 100% certain.
$25 shipped
Are they already glued together?Does the outer aero(part that will be seen) have any chips or defects?shipping to 43725?
They are glued together no chips or anything on outer flare. Let's just call it $25 shipped
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
The late 80's early 90's car's OEM speakers were of the same quality as today's offerings. The main difference was the rear speakers were enclosed...
10
You're not trying to figure out the mass of air in your 3" port or whatever, you're trying to figure out the mass of air that you would need in an...
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
tc3k101
Ω
tc3k101
Socal
tc3k101
SPLBassJunkie
    May 21, 2024
    May 20, 2024
