Sold fs: tools, amps, speakers, subs
bdubs767
Need some new toys and to pay off a speedign ticket //content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif//content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif
Kicker SSMB 6.5" BNIB Killer mid basses $65
PG RSd12d BNIB $80
PG RSd12d not sure if I wanna sell it as I love it and I could use it some where else but Ill say $80 for it, its been used for 2 weeks no more then 20 hrs total.
PG TI elite 6m...I cleaned em up being using em for about a week now sound like they should. Got rid of all the bumps in the surrond cleaned the rust, and armoralled the surrond. They look alot better...
$95 for the pair..pics are old Ill get new ones if some one wants em
Audio Control RTA $750 used but in perfect condition.
Pioneer PRS X720 $230
2-Pioneer PRS X320 $200
Pioneer PRS x220 $180
They All are brand new and beign bought from my firend whos a dealer thus you'll get warranty ect with them. They were only on a display board never seen power. Also fyi these amps ALL put out double their rated power.
specs are here....
x220
http://www.pioneerelectronics.com/pn..._32906,00.html
Specifications
* Continuous Power (20Hz-20kHz, 0.04% THD)
o 2 ch: (4 Ohm) 30Wx2
o 2 ch: (2 Ohm) 60Wx2
o 1 ch: (4 Ohm) 120Wx1
* Maximum Power (EIAJ)
o 2 ch: (4 Ohm) 75Wx2
o 1 ch: (4 Ohm) 225Wx1
* Frequency Response: 10Hz - 50kHz (0,-1dB)
* Total Harmonic Distortion:
* Signal-to-Noise Ratio: >100dB (IHF-A Weighted, at 1kHz)
* Dimensions: 10-3/8" x 2-1/2" x 9-1/2"
Features
* Bridgeable 1/2/3 Channel Capability
* PWM Regulated MOSFET Power Supply
* 2 Ohm (4 Ohm mono) Optimized MOSFET Output Section
* Balanced Isolator Input Circuit
* Oversized Gold-Plated Screw-Type Power/Ground Terminals
* Gold-Plated Screw-Type Speaker Terminals
* Gold-Plated RCA Inputs
* Gold-Plated RCA Outputs (Full Range)
* Hi-Volt Input Level Control (400mV-6.5V)
* Variable Crossover: 50-120Hz, -12dB/oct. (LPF/HPF)
* Variable Bass Boost (40-120Hz, 0 to +18dB)
* Premier Power Certification Sheet
* Premier Two-Year Warranty
x320
http://www.pioneerelectronics.com/pn..._36992,00.html
Specifications
o 2 ch: (4 Ohm) 50Wx2
o 2 ch: (2 Ohm) 100Wx2
o 1 ch: (4 Ohm) 200Wx1
o 2 ch: (4 Ohm) 125Wx2
o 1 ch: (4 Ohm) 375Wx1
* Dimensions: 10-3/8" x 2-1/2" x 11-3/8"
Features
* Subsonic Filter (15Hz, -18dB/Oct.)
x720
http://www.pioneerelectronics.com/pn..._34073,00.html
Specifications
o 2 ch: (4 Ohm) 100Wx2
o 2 ch: (2 Ohm) 200Wx2
o 1 ch: (4 Ohm) 400Wx1
o 2 ch: (4 Ohm) 250Wx2
o 1 ch: (4 Ohm) 750Wx1
* Signal-to-Noise Ratio: >105dB (IHF-A Weighted, at 1kHz)
* Dimensions: 10-3/8" x 2-1/2" x 13-5/8"
Features
Audiobahn (PANDY) 200 amp cirvut break...I foudn it in my box of extra wire. Still works, the crack is only cosmetics... $8
4 channel 20' and 3' of nice RCA wire....quad protected the cloth outside, thick rubber, tin foil, finally ruber around the wire. $10
bdubs767
bdubs767
Mass/ VA
HawaiianBassHed
