FS: Taramps HD4000 2 Ohm Version
$LICK CALIFA$
Max. Output Power @ 13,8 VDC - 2 OHMS - 4798W RMS
Max. Output Power @ 13,8 VDC - 4 OHMS - 3171W RMS
Max. Output Power @ 13,8 VDC - 8 OHMS - 1876W RMS
Max. Output Power @ 12,6 VDC - 2 OHMS - 4000W RMS
Max. Output Power @ 12,6 VDC - 4 OHMS - 2644W RMS
Max. Output Power @ 12,6 VDC - 8 OHMS - 1564W RMS
Input Sensitivity: 250mV @ (-9,78 dBm)
Total Harmonic Distortion (THD): 0,3%
Signal / Noise Ratio: >95dB
Damping Factor: 400
Frequency Response: 5Hz a 15KHz
Crossover:
H.P.F (High Pass Filter): 5Hz to 50Hz (-12dB/octave) Variable
L.P.F (Low Pass Filter): 50Hz to 15KHz (-12dB/octave) Variable
Input Impedance: 18K OHMS
Protection System: Short into Output / Power Supply High / Low
Minimum Supply Voltage: 10,5VDC
Maximum Supply Voltage: 16VDC
Idle Consumption: 2 Amp.
Musical Maximum Consumption @ 12,6VDC: 202.5 Amp.
Sinusoidal Signal Maximum Consumption (1KHz) @ 12,6VDC: 405 Amp.
Dimensions (LxAxP): 229 x 65 x 375mm
Weight: 4,12Kg/9.23 lbs
Got it in a trade but I have too many amps in this power range so it has to go!
Comes with box, manual/paperwork and clip indicator.
Pics below show condition.
2nd pic shows blue led power light on along with the clip indicator as well.
$425 shipped obo lower 48 - cash is king but pm trade offers
$LICK CALIFA$
$LICK CALIFA$
Not Far!
$LICK CALIFA$
