FS: Taramps 20.2kw amp
72Impala
1. Product: taramps 20.2kw amp
2. Specs:
Classe de Operação - (D)
- Potência Máxima @ 12,6 VDC - 1 OHMS - 20200 WRMS
- Filtro Subsônico (Variável) - High Pass - 5Hz a 50Hz (-12dB/8ª)
- Crossover (Variável) - Low Pass - 50Hz a 5KHz (-12dB/8ª)
- Diagnóstico Eletrônico - (Leds Indicadores):
On - (ligado)
Clipling - (distorção)
Proteção - (proteção de curto)
- Sensibilidade de Entrada - 300mV a 6V
- Impedância de Entrada - 20K OHMS
- Resposta de Frequência - 5Hz a 5kHz
- Tensão de Alimentação Mínima - 10,5VDC
- Tensão de Alimentação Máxima - 15VDC
- Consumo em Repouso - 1 Amp.
- Cons. Máximo Musical @ 12,6VDC - 905 Amp.
- Cons. Máximo em Sinal Senoidal (100Hz) @12,6VDC - 1890 Amp.
- Dimensões (LxAxP) - 291 x 56 x 730mm
- Peso - 14Kg
^^ that's from the site haha. Draws 905 amps on music, can draw up to 1890 on a sine wave. 1 ohm stable single channel amp with two x speaker outputs (although it is still one channel), 20,200 wrms on 12.6 wired to 1 ohm is what they claim, I know over 16kw has been clamped from these. Every battery you add the amp will produce more power. I CLAMPED 18,029 out of this amp today. Starting at .6ohm rising to .81!
3. Description/Condition:
9/10 cosmetic tiny scratches here or there, I have a plexi bottom (pictured), and a black aluminum bottom plate, both will be included. The inputs are 10 x 1/0 gauge inputs made by rose auto, they are very nice and included IN A FULL PRICE SALE, any less than asking and they aren't included.
4. Price: : $1450 shipped conus, OBO if you don't want the inputs.
5. Pictures:
B]5. Pictures: [/b]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/br]
[br][/
72Impala
72Impala
Clarksville, TN
hispls
