FS: Sundown Audio SAX 100.4 D ***********************
350zspl
The version with 3 x 30 amp blade fuses , not the newer version with 2 x 40 amp blade fuses
Near Mint Very Lightly Used , Was Tie Strapped So Mounting Feet Never Had Fasteners & Remain Unblemished
I bought a new SAX-100.4 V.2 ( That Said The Amp For Sale Today Will Come With My New Amps Double Boxed Set Including Everything Pictured )
Outer Sundown Carton
Inner Sundown Box
New Un-used Bass Knob Wire
New Un-used Bass Knob With Clipping Indicator & Power Light
Inner Plastic & Foam
Amp Brings A Printed Owners Manual From This Link :
http://sundownaudio.com/product-manuals/SAX504_1004_1252.pdf
Amp Specs
Rated power output
----RMS power, 4 ohm stereo 100W x 4CH
----RMS power, 2 ohm stereo 160W x 4CH
----RMS power, 4 ohm bridged 320W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~5kHz (CH1&2)
50Hz~5KHz (CH3&4)
(50-500 with x10 switch)
Selectable 12 or 24 dB slope
High Pass Crossover
50Hz~5kHz (CH1&2)
50Hz~5kHz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
THD@RMS Watts
Channel Separation 75dB
Fuse Rating 30A x 3
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 480(L)mm
$300.00 Inclusive Of Pay Pal Fees
Buyer Pays Actual Shipping Costs
350zspl
350zspl
WPB Florida
350zspl
