Sold FS subs and amp
no idea... never taken them out of the enclosure to find out...
i would be inclined to say its what ever is most commonly found...
if it helps they were bought at Tweeter...
they work with a 250/1 so idk
sorry i can go take them out and tell you, but i'd have to use a leathermen....
jl 250/1...
Description: Class D Monoblock Subwoofer Amplifier
Patented Technology: High-Damping Class D Circuit with discrete control circuitry
Differential-Balanced Input Topology: 1 pair of inputs
On-board Crossover: Fully-variable (40-200 Hz), selectable-slope (12 or 24 dB per octave) LP
Bass EQ: Variable boost up to +15dB
Infrasonic Filter: Defeatable 24dB / octave at 30 Hz
Signal-Sensing Turn-On: Permits operation without remote lead
Dual mono speaker output connections: Accept up to 8 AWG wire
+12V and Ground connections: Accept up to 4 AWG wire
those specs are for the 250/1v2 but its essentially the same thing, the main change i believe is the cooling fins.
andrewmoore13
andrewmoore13
Gloucester, MA
andrewmoore13
