Sold FS:Subs, Amps, Components
Midnightaccord
Hi, im selling this stuff
Rockford Fosgate RFP3412 (2 of them) Punch HE series
400W Max
200 RMS
4 ohm
Custom fiberglass and particle board box made for 12's
made to fit in back of 98-02 accord sedan but fits in anything
Concept CC-1252 amp
2 ohm stable
2-channel amp
120w x 2 @ 4 ohms
200W x 2 @ 2 ohms
Concept CC-752 amp
2-channel amp
2 ohm stable
75w x 2 @ 4 ohm
105w x 2 @ 2 ohm
Concept 6.5 components
heres specs for the 6.5 components:
Product #: CXN-650
Description:
Peak power handling: 250 watts
Continuous power handling: 150 watts
Impedance: 4 ohm
Frequency response: 50Hz-20KHz
Rugged, Textured Silver Stamped-steebasket
Neodymium Magnet w/ Die Cast Aluminum Cover
Durable Rubber Surround
Lightweight Brushed Aluminum Injection Cone
25mm Soft Dome NeoDymium Swiveling Tweeter
12 dB per octave crossover
Sensitivity: 93dB
Grills and almounting hardware included
specs for cc-752:
RMS Power 75W x 2 @ 4 Ohm
RMS Power 125W x 2 @ 2 Ohm
RMS Power 250W x 1 @ 4 Ohm MONO
Signal-to-noise ratio: 100 dB
Frequency Response: 5Hz - 50kHz
Total harmonic distortion: 0.05%
Continuously variable 0 - 18dB BASS boost
Built-in continuously variable 18dB per octave crossover
Remote bass level control “port” (remote RM-100 available separately)
Input sensitivity: 200mV - 4V
Platinum connectors
Size: length x width x height: 300mm x 296mm x 60mm
9.75" x 11.66" x 2.37"
Midnightaccord
Midnightaccord
In the drivers seat
Midnightaccord
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
