Sold FS: Street Max van :(
btnhfan
Hail to the King Baby!!!!
I am forced to sell my baby unfortunately. It has a massive enclosure ready for a bandpass, and in my testing with an 18" apx with a few hundred watts, was doing mid 140s with the enclosure not even done. I know it will be very loud when completed. I cannot finish it due to lack of funds, college, and the need for a more practical daily driver.
I cannot even count the amount of hours I put into it, but it was all me in building it. I had no help.
This could also be a perfect bass race ride with 80ish cubes total.
However not everything is good. There are some ****** problems with shifting (my guess is because of the weight). The dash does not light up (we think a ground came loose behind the dash). And now it is leaking gasoline from a rubber hose coming from the fuel pump. I do not have the monetary means nor mechanical knowledge to fix this.
It has 3 tires with less than 2k miles on them. I couldn't put the fourth on because the tire guy was afraid of snapping the stud. I will include the 4th tire with the van.
I am going to sell it gutted with only the wood enclosure in it. It has 3 layers of mdf on every wall and an external 2x4 frame that makes it feel like concrete.
If you want it with both or one apx's, and the nsb up front, and the 12 runs of 20ft kicker wire, let me know. We can probably work something out.
I really don't want to send it to the junkyard because of all the work I put into it. It is in midtown ATL right now. I am going to let it go for very, very cheap.
Here are some pics.
Feel free to ask me anything.
codes are easy to check dude. Turn the key on, off, on, off, on, off, on. Watch the check engine light. Count the blinks. There will be some blinks, then a pause, then some more blinks. Thats the code. ie blink, blink, blink, pause, blink, blink. First set is 3 next, 2, so code 32, then it pauses and goes on to the next
btnhfan
btnhfan
CT/ GA Tech, Atlanta
malic
