Sold FS: RD 1750's, Atomic 4 Channel, Odyssey 2150's, TC OEM 10
photocrazy8
Probably doesn't like you
A brand new, never powered Atomic Trinity 504 4 Channel
* Stable into 4 ohms bridged or 2 ohms load workable
* 2 ohms bridged load workable at music playing
* matched Bi-Polar output transistors
* dual transformer
* 12 dB low pass and high pass crossover
* 18 dB bass boost equalization variable control
* Input sensitivity variable: 7V – 250mV
* 3 way protection Circuit: over voltage, speaker short and thermal overload
* S/N ratio :> 105dB
* THD:
* size – 9.0” x2.50” x 11.8”
RMS – 170W x 2 ch @4 ohms mono
- 85 W x 4 ch @2 ohms stereo
- 50 W x 4 ch @ 4 ohms stereo
$160 shipped...
Then I have two RD Audio 1750's. They are great amps and under rated. 1750 watts @ 1 ohm. http://rdaudio.net/rd1750/rd1750.htm $400 Shipped each...
Then i have two odyssey 2150's. they are in great condition have are only about a year old. never seen below 12 volts at all. $200 plus actual shipping. Local pick up preferred... (three are pictured but im keeping one for my next set up)
SOLD LOCAL
Then i have one of the OEM 10's that were the normal production ones with the nomex cone. This one is dual 4 ohm. $140 shipped
28mm xmax
800 watts RMS
1190 ounce motor
3" wide, long-wind voice coil
Dual 8.5" spiders with woven leads
Lightweight honeycomb glass fiber cone
Single 4 ohm DCR or Dual 4 ohm DCR
SOLD
photocrazy8
photocrazy8
CA
LuvnThatBass
