I am selling all my stereo stuff.
Pioneer Premier 12" Subs (Used)
I have 4 of them There in perfect shape.
Only have about 4 hours on them all together.
TS-W3001D4
Woofer Cone Material Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround Wide-Roll, 3-Layer Fiber Woven Aramid Radial with Honeycomb Cloth
Voice Coil Dual 4-Layer, Long Voice Coil
Voice Coil Wire Copper
Voice Coil Bobbin Phenol Resin Coated Glass Cloth
Projected Pole Yoke with Vented Pole
Magnet Construction Double Stacked (110oz)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Integrated Single-Sided Silver Compression Terminals
Specifications
Watts MAX. Music Power 3000 Watts
Watts Nominal Power Handling 1000 Watts
Frequency Response 18 Hz to 700 Hz
Sensitivity 89 dB
Ohm Rating D2: (1 or 4 ohm) D4: (2 or 8 ohm)
Recommended Enclosure 0.50 ~ 1.0 Cubic Feet
Dimensions 329 mm x 214.2 mm
Mounting Depth 188.8 mm
135 Shipped Each
I have two Nesa 7" Monitors used but in great shape.
Will include the A/V box and remotes.
90 Shipped Each
Hifonics Zeus 6406 4-channel amp.
85 watts RMS x 4 chan. at 4 Ohms - 170 watts RMS x 4 chan. at 2 Ohms - 340 watts x 2 chan. at 4 Ohms
It does have a mark on the face of it.
145 Shipped
TS-W3001D4
Specifications
Sensitivity 89 dB
135 Shipped Each
90 Shipped Each
145 Shipped
