Sold FS: Pioneer Premier 12's, 7" Monitors, Hifonics Zues 6406, 8" 10" Midbass woofers ETC
ReDemoN
I am selling all my stereo stuff.
Pioneer Premier 12" Subs (Used)
I have 4 of them There in perfect shape.
Only have about 4 hours on them all together.
TS-W3001D4
Woofer Cone Material Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround Wide-Roll, 3-Layer Fiber Woven Aramid Radial with Honeycomb Cloth
Voice Coil Dual 4-Layer, Long Voice Coil
Voice Coil Wire Copper
Voice Coil Bobbin Phenol Resin Coated Glass Cloth
Projected Pole Yoke with Vented Pole
Magnet Construction Double Stacked (110oz)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Integrated Single-Sided Silver Compression Terminals
Specifications
Watts MAX. Music Power 3000 Watts
Watts Nominal Power Handling 1000 Watts
Frequency Response 18 Hz to 700 Hz
Sensitivity 89 dB
Ohm Rating D2: (1 or 4 ohm) D4: (2 or 8 ohm)
Recommended Enclosure 0.50 ~ 1.0 Cubic Feet
Dimensions 329 mm x 214.2 mm
Mounting Depth 188.8 mm
135 Shipped Each
I have two Nesa 7" Monitors used but in great shape.
Will include the A/V box and remotes.
90 Shipped Each
Hifonics Zeus 6406 4-channel amp.
85 watts RMS x 4 chan. at 4 Ohms - 170 watts RMS x 4 chan. at 2 Ohms - 340 watts x 2 chan. at 4 Ohms
It does have a mark on the face of it.
145 Shipped
8" Midbass subwoofer.
These are the 4 ohm version
Used for about 3 months.
The Heavy Duty PC Series is available in 4 ohm and 8 ohm versions for automotive and home audio applications. The woofers handle the most powerful of amplifiers while maintaining sonic excellence. They feature aluminum die-cast frames, knurled and gold-plated binding posts, rubber surrounds, and vented pole pieces with bumped back plates. Specifications: * Power handling: 120 watts RMS/230 watts max * Voice coil diameter: 1-1/2" * Frequency response: 45-7,000 Hz * Magnet weight: 30 oz. * Fs: 45 Hz * SPL: 91 dB 1W/1m * Vas: 1.77 cu. ft. * Qms: 4.2 * Qes: .72 * Qts: .62 * Xmax: 3.21mm * Net weight: 5-1/4 lbs. * Dimensions: Overall Diameter: 8", Cutout Diameter: 7-1/8", Mounting Depth: 3-11/16", Magnet Diameter: 4", Magnet Height: 1-1/4".
50 Shipped for the pair
10" Selenium Midbass woofers (4-ohm)
I really dont have any specs on them Im trying to find some info
75 Shipped for the pair
6 1/2 Eminence midbass woofers (used) (4-ohm)
Recommended for professional audio midrange applications in a sealed cabinet, or as a mid-bass in a vented satellite enclosure. The Alpha-6C boasts a 4-ohm impedance, increased body weight, and stiffer, more aggressive water proofing treatment on the cone making it ideal for car audio use. Specifications: *Power handling: 100 watts RMS *VCdia: 1.5" *Le: 0.28 mH *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 107-6,000 Hz *Magnet weight: 20 oz. *Fs: 107 Hz *SPL: 93.6 dB 1W/1m *Vas: 0.2 cu. ft. *Qms: 6.12 *Qes: 0.49 *Qts: 0.45 *Dimensions: Overall Diameter: 6.59", Mounting Diameter: 5.69", Mounting Depth: 2.8".
Kapton coil former
Polyamide-imide coated copper voice coil
Pressed steel basket
Paper cone with cloth cone edge
Solid composition paper dust cap
65 Shipped for the pair
Pyramid super tweeters.
Everyone knows about these old school jems.
35 Shipped for the pair
Stuff I dont have pictures of right now.
3 sets of 15 foot Rca wires (Stinger Blues) 10 Shipped each
1 - 4 gauge Grounding Foot 5 Shipped
160 amp High output Alternator for a 92-95 Civic With a Single cam motor 150 Shipped will include the 1/0 gauge power wire with the fuse and fuseholder
Black covered Prefab 12" dual speaker box 50 Shipped
Any ?'s pm me of post on here.
If your wanting any more pictures of certain things send me your e-mail address
I will e-mail them to you.
Thanks.
Cody
hey man, i think the selenium 10'' are 8 ohm each, should also be around 150 rms and 300 watts peak, they get pretty **** loud for there ratings, i used to run 12 of them... Great prices and good luck with the sale.
Yeah it may be.
As a matter of fact they are 8 ohm.
And they are loud as hell.
I loved them.
Wish I would have thought of doing that years ago.
ReDemoN
ReDemoN
Tifton, GA
ReDemoN
