Sold FS: Pheonix Gold line driver $50 shipped
  • Thread starter pimpin
  • Replies 0
  • Views 328
pimpin
yerp
Phoenix Gold PLD1 / TLD2 Line Driver
- good working and cosmetic condition
Mine is white!
features:
-Isolated Mounting Clips
-Variable Output Level Control
-Peak Level LED Indicator
-24kt Gold Plated Input And Output Connectors
-Pulse Width Modulated Power Supply
-Quick-Connect Power Connector
Phoenix Gold's PLD1 high voltage line driver makes the most of your car audio system by transmitting up to an 8 Volt signal from the source unit to the rear of the car. This method of transmitting the audio signal increases dynamic capability and decreases the possibility of noise radiating into signal cables.
This line driver boosts the signal up to 20dB, allowing the next component to operate with lower input sensitivity setting for a higher signal to noise ratio. The PLD1 also features a 30ohm output impedance that enables it to drive long signal cables to multiple components with ease. The PLD1 maximizes sound quality further with a peak indicator that simplifies proper gain adjustment.
Manufactured with high quality parts, the PLD1 features a G10 glass epoxy circuit board and audiophile grade 1% metal film resistors. Choose either the sleek high gloss white powdered coated finish or black.
pimpin
yerp
pimpin
Allentown, Pa
pimpin
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
