Sold fs nib 2 old school rockford fosgate hx2 15s new
loudmofo
i have 2 new old school rockford hx2 15s 4in coils dual 2ohm subs .
$600 shipped on both subs
specs :
Its FIBERlock treated paper cone handles an awesome 1,000 watts RMS for incredible competition-level thump. For championship-quality strength, the cone is bathed in a special "high solids" solution that ensures it can support the weight of a heavyweight prizefighter! The 2-ohm dual voice coil structure is designed to maximize amplifier performance and provide more system hook-up options. The coils themselves contribute to this woofer's brute force — they are more than 2 inches long, enabling the cone to travel 50 percent further than in Punch HX2 series subwoofers.
The vented plate helps the sub handle temperatures of more than 400 degrees without distortion, while the Santoprene rubber surround withstands all types of adverse weather. In all, it's an amazing blend of sound quality and unadulterated power.
Note: If you are wiring this DVC sub for lower impedance, make sure that your amp is compatible. Most car amplifiers are stable down to 2 ohms in standard mode, or 4 ohms in bridged operation.
Details:
  • FIBERlock treated paper cone with Santoprene™ rubber surround
  • frequency response 22-400 Hz
  • power range 150-1,000 watts RMS (500 watts per coil)
  • peak power 2,000 watts
  • sensitivity 87.5 dB SPL
  • dual voice coil design (two 2-ohm coils)
  • top mount depth 7-15/16"
  • sealed box volume 1.25 cubic feet
  • ported box volume 2.0-4.0 cubic feet
  • Recommended Q-Logic Box Type: 1, 2
loudmofo
loudmofo
Providence, Rhode Island, United States
amartin_72
