Sold FS: My whole car's worth of audio (*amps, mids, tweets, xovers*)
Well, it was brought to my attention last night that i owe my father somewhere between $800-900, and as such everything in my car has to go to help me make that number as soon as i can. So, everything i have in its state of audible bliss has to go //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
Everything is in great, fully functional condition.
Boston Acoustic Rally Series RC620 6.5" Midwoofers
These speakers are 4 ohm, and as Beat_Dominator will attest, they are loud //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I fed them somewhere around 160 watts and it really felt like they wanted so much more, these things can handle inane amounts of power! In my well-deadened door situation, midbass was strong, mids had clarity, it was most everything i wanted in a midrange speaker.
Boston Acoustic 620x Crossovers
This is the crossover for the RC620 component set, well built, but keep in mind its a decent sized crossover, because of the build quality, so you'll need a bit of space for them.
AURA MR620 1" Tweeters
This is the tweeter i used to replace the RC620 tweeter when i bought the RC620 component set because its far more robust. This is not the Aura Silk Dome tweeter that everyone went nuts over, its the tweeter from the MR620 set, handles more power, and is a bit louder as a result.
Tweets + Xovers + Midwoofers (Component Set)--> $175 SHIPPED!
Profile Clarus CL800 Amplifier
This is a great amp to power a small to midrange sub on, or for powering a nice beefy set of midbass speakers (perfect for XXX mids). I ran the amp at 4 ohms and had gains set to about half sending power to my set of Boston Acoustic RC620 speakers, sounded great. Great solid amp on a budget.
Specs:
Picture of the clarus without the gold thing on it (taken with my cell phone because my digi camera broke)
$90 SHIPPED!
Profile California AP400 Amplifier
I used this nice little amp to power my tweeters, running actively, for the past couple months now. Gains have never been set above 1/2, never taken into clipping or even speaker distortion. Perfect little amp to run a set of tweets on if you need to run active. I was able to fit it hidden next to my spare under the floor mat.
Specs:
RMS Output Power(4 Ohms)-65W x 2
RMS Output Power(2 Ohms)-100W x 2
Bridged RMS Output Power(4 Ohms)-200 x 1
MOSFET Power Supply
Total Harmonic Distortion-
Signal/Noise Ratio-103 dB
High/Low Level Converter(Male RCA)-Yes
Pre-Amp(RCA) Outputs-Yes
Variable Bass Boost @45Hz-0-12 dB
12dB/Octave Crossover-HP/Full/LP
Variable LP Crossover Frequency-50 - 250 Hz
Variable HP Crossover Frequency-80 Hz -1.2 kHz
Fuse (s)- 25A
Dimensions-2"H x 10 1/4"D x 7 3/8"W
Power/Speaker Terminal Size (Gauge)- 6/6
$55 SHIPPED!
Also, all the wiring from my car. But i don't have it measured out yet, i'll list it up later.
references
req (x2)
valant94gt
ngsm13
spicmonster
desertheat
FRITO (x2)
vitveet
Toy_Tundra
188 positive feedback on eBay as well.
PM me or talk to me on AIM if you want to discuss anything!
interested in the wiring. let me know watcha got. Looking for lots of 2 or 0 guage wire, fuse & fuse holder, and maybe some distro blocks.
And if I had known about that component set about a month ago I would have jumped on it!
bump.
bump.
Thanks =]
Wiring i have is 4 gauge from the battery to the back, 125 amp inline near the battery, maxi-fused distro at the back that has 8 gauge leads to the amps, 8 gauge ground system with a nonfused distro block.
twoohfour
okay
twoohfour
Where you live (Ex. Los Angeles, CA)
brokenbmx06
