Sold FS:Memphis 4kw *NEW*
MEMPHISFLEX
Dont know how this will work out since Ive made alot of enemys on here and so forth, but ill try it! Ill ship first, and everything. So anyways I have one of my Memphis 4kws left, this one was in my buddies demo build for his shop, hes a memphis dealer, used very very little maybe 20min of play time at most, did a couple shows with it thats it. Had it hooked to two Memphis 08 mojos at 1ohm, never dropped below 13.5volts. The amp was clalmped at one of the comps at 4460wrms @1ohm at 13.8volts, and these are .5ohm stable. Still have all orginal boxes, manuals, plastics, will have the full memphis 2 year warranty also! Gunna ask $660shipped, which is cheap for a pretty much brand spanken new one, I have seen used ones go for that much!! Trades welcome!
edit:Ill get pics up as soon as I can, the wind is making my sat. internet really slow, and cant upload on photobucket.
mojo 2500 and 4000's are far from mainstream. i dont see you only getting 2400 out of a 4kw at all when tons of people have tested on a 12v system seeing 3600-3800 on a regular basis. yes where this amp does excell at is a low ohm load on 16v. some people have seen upwards of 6k out of an amp. one problem with this amp is that its power hungry and will eat your voltage which doesnt help power output unless u got a real charging system.
so just because u dont like this guy dont try to mislead his thread. and what the hell is a true rms clamp meter? FLUKE?
if u only tested 2400rms turn something up because thats not close to correct. and ur trying to compare the mojo line to planet audio..............
Yes thank you, and the test done were at comps, i have no control I just know this particular amp did those numbers. the memphis 2500d does over 3kw so the test results that guy got must of been from the older MCD2000 Mojo or something..lol.. and as far as my dealing on here, R/T Pimp and I worked out our stuff, going to his house this weekend, Hemi22 got his wire, and bushj311 is getting a money order sent out today! And thanks Terra means alot!
Sorry not to attack it but that thing I highly doubt was clamped at that. We have clamp tested many of the 4kw's with a true RMS clamp meter and a DMM. We tested a few on a 12volt system with voltage dropping around 10.8 to 11 volts (i know low) but wired .5 ohm with imp rise to .8 and only seen 2400watts RMS from each of the amps. And More recently tested a few of the amps on a 18 volts with drops down to about 16 for burps at a wired .5 ohm with imp rise to about 1 and only got 5,000 to 5,100 out of each of them. So wired .5 ohm and 16 volts 5k vs 13.8 and wired 1 doing 4400... sorry I think they were tested with an inaccurate method. But in all honesty the amps are GREAT amps. Most mainstream amps dont' test what they should. Planet audio for example 2300 watts RMS.... True 1 ohm does about 1800. and a wired 1 ohm after imp rise doesn't do more than 1400 to 1500.... So I guess by traditional standards the amp does pretty close to 4kw. But don't use terms like clamp meter because then it gets all technical.... Sorry there again not to attack the post but on that clamp test it was done inaccurately most likely. But for that amp it is a good price
Mine was clamped by tommyk a few days ago at arround 3100 or 3200 watts a few days ago at arround 12.9 volts.
Ummm these test were done out of the durango in lafayette at RP's shop. And the other high voltage test were done on the new SS van they are building. It is basic math... amperage times voltage equals wattage.... And who says the test you READ are accurate either come on man... you are taking way too much offense to this. And memphis is mainstream. And I did the exact same test on my kole 2400d and it is doing 1400watts rms at 1.3 ohm with imp rise. you telling me that amp is over a 1600 watt rms amp? same method same results.. If you argue the results you argue that the kole 2400d does more than 1500 to 1600 rms
And actually a True RMS meter.... Pretty sure I am thinking of the correct term here. Either way not all Clamp meters are. Some clamp meters only clamp ac voltage at 60hz and if you try at a different freq you will get an inaccurate reading. But with a true RMS it tells amperage at any freq in ac. True RMS has nothing to do with brand. It is a design
and i am sorry that it offends some people. Anybody can test them. I didn't "alter the test" just to make it look like this. We were shocked because I thought the amp did a lot more as well. And actually I have talked to a few competitors and I hear the same thing on a 12volt dipping down they don't do very much. They see their power at 16 volts. So get mad. Try to attack me in any way. Doesn't change the fact of what the test shows... not what marketing that you live by shows. It is still a **** good amp. considering a rockford 20001 2000 watts is shop cost close to same price as memphis 4kw. I didn't doubt that. I can only show what test results show.
EXACTLY... sounds about right. Said 2400 in the 10 volt range
That was a conversative gain setting as well.
Adjusted it some more and upped it to a little over 3400 watts. His RESTING voltage with the car on was only 13.9 which isn't great to begin with.
I'm sure with some more tweaking and better voltage, 4000 could be attainable at 1 ohm which is pretty stout.
MEMPHISFLEX
MEMPHISFLEX
Chicago,IL
TwistedMayhem
